02-07-2012 10:22 AM
I have recently purchased the Embedded Software Evaluation Kit which comes with LV8.6 90 day evaluation of FPGA, RT... and although I have sucessfully worked through the tutorial that with the kit I came across a problem when trying to run a remote web panel such that it showing loading 0% but never proceeded past this point.
After trawling through many discussion forums I came across a post which gave one of the reasons for this to happen as being due to having a newer version of LabVIEW run time engine installed on the PC - only by removing LabVIEW 2011 could I get the web panel to run.
My question is how do I manage multiple version of LabVIEW if I wish (and I do wish) to install more than one version of LabVIEW and still be able to run a remote panel via LV8.6?
Cheers,
Helen
Solved! Go to Solution.
02-10-2012 04:30 AM
Hi Helen,
With development versions of LabVIEW you can deactivate them (using the NI license manager), but since the run-time engines are not licensed you can not deactivate that.
You could try running one of your LabVIEW versions in a virtual machine, thus separating them from each other.
I apologise for the problem that you have encountered, I appreciate that it inconveniences you quite a bit, but I assure you that your R&D team are looking into the issue.
Kind regards,
02-10-2012 06:23 AM
Hi James,
Thank you for your reply.
Your virtual machine solution does provide me with a work around - just need to google how to go about this!
Kind regards,
Helen
