Embedding charts and graphs in html report
I am passing several waveform chart and XY graph references in a html report, using 'Append Control Image to Report'. They all show up in the report nicely. That's not the problem. The problem is, the location where they are saved, all the charts and graphs gets saved as separate jpg files.
Is there anyway I can embed the pictures directly in the report and not have to deal with the extra jpg pictures.
(4,045 Views)
I am not understanding what you mean.
Graphics in HTML files are either BMP, JPEG, or PNG.
If you want one giant graphic then you will need to "stitch" your graphics into one JPEG or PNG file yourself.
(4,042 Views)
What I meant is, the Append Control Image to Report VI saves the image files to a directory, creating extra png/jpg files. Is there a way, I can directly embed control images into the report, not having to deal with the extra image files.
(4,038 Views)
You cannot embed graphics in a HTML file. Read up on it. It isn't Word.
(4,035 Views)
Hi ipc,
Thank you for using NI Forums. I don't see a way to do this without creating the actual png/jpg files, but I'll play around with this VI and if anything magical happens I'll be sure to post about it!
Dan T.
(4,018 Views)
