Enable/ Disable Comport from PC
If you want to achieve something within your LabVIEW User interface and nothing to do with Physical  Communication Resource.
Get all the COM Ports and Update the ring and Control the Disabled items to enable and disable the Ports in the LabVIEW UIDisableEnablePorts.png
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 11 of 11
(61 Views)
