Enable Windows Explorer for LLB in LabVIEW 8.5.1
I have a fresh install of LabVIEW 8.5.1.  I would like to treat an llb as a folder in Windows Explorer like I have in the past.  The only problem is that this option was typically available in Tools->Options->Environment.  I doesn't appear to be there in my 8.5.1 installation.  Is there an alternate procedure I can use to turn on this feature in 8.5.1?  It would be a shame if this functionality has gone away.  My OS is XP Pro.
Greg
(2,637 Views)
Hi Greg,
There is a workaround for using Windows Explorer instead of LLB manager to handle your LLBs. This knowledgebase explains the steps.
Instead of using Windows Explorer, LabVIEW 8.5+ uses LLB Manager. This information can be found on the upgrade notes for 8.5.
Warm regards,
Karunya R
(2,601 Views)
