Enabling Web Server causes Access Violation OxC0000005 when launching compiled code
I have a program that runs fine from the development system. The web server is running and I can access the panel remotely.
When I build and deploy the executable to the target machine I get the error Access Violation OxC0000005 on launch.
If I build the same code without the web sever enabled it runs fine.
=== Engineer Ambiguously ===
(3,136 Views)
We had the same problem with a different thing. The problem turn out to be that the application builder was moving a copy  of a the winsys32.dll into the data file and one was resident on the computer. If we deleted the extra out of the data file the problem when away. I would look for something like this. What dlls are in your data file when the application is being made?
Tim
GHSP
(3,132 Views)
Same problem happening to me with LV2011, running complied EXE with Web Server enabled.  I do not have any DLLs in the "data" folder other than "lvanlys.dll" which is typical.
(3,091 Views)
