Enabling XNode development in LabVIEW 2020 – .ini flags
Hello everyone,
I’m trying to enable XNode development mode in LabVIEW 2020 64-bit.
So far, I’ve added the following keys to my LabVIEW.ini file:
Xnodewizardmenu=True
XnodewizardMode=True
XTraceXnode=True
XNodeDebugWindow=True
SuperSecretPrivateSpecialStuff=True
XNodeDevelopment=True
XNodeDevelopment_LabVIEWInternalTag=True
I’m sure this is the correct .ini file because the XNodeWizardMenu does appear when I right-click on a VI (for example on Match Regular Expression.vi).
However, in the Project Explorer the New menu does not show XNode (below XControl), which I was expecting.
My questions are:
  1. Is there an additional .ini key required in LabVIEW 2020 to make New → XNode appear?
  2. Can someone explain what each of these flags actually activates?
  3. Has anyone managed to get the Project Explorer “New → XNode” option visible in LabVIEW 2020?
Thanks!
Youssef Menjour
Graiphic
www.Graiphic.io
y.menjour@graiphic.io
LabVIEW architect passionate about robotics and deep learning.
Follow us on LinkedIn
linkedin.com/company/graiphic
Follow us on YouTube
youtube.com/@graiphic
(897 Views)
Hi Youssef,
To develop XNodes properly on Windows, it requires a special licence that I think only NI developers can have.
You can still use a third party editor though.
Useful links:
Some XNode documentation: https://lv.qizhen.xyz/en/oop_xnode
The XNode Editor made by Hooovahhh.
Raphaël.
(851 Views)
