Enabling/disabling plots in a multi-plot XY Graph...
As in the title. I have an XY Graph with multiple plots in the region of 5-10. I am updating the graph via a queue containing an array the of plots. I want to be able to view some or all of these plots at any specific time, and for the visible plots to be changeable whilst the program is running. However, I am not sure how to achieve this and after looking at the available properties of the graph I am still none the wiser.
Please advise. Thank you.
James
Never say "Oops." Always say "Ah, interesting!"
Message 1 of 9
(7,431 Views)
Use the Active Plot and Plot.Visible properties to select/deselect plots.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 2 of 9
(7,419 Views)
Something like this:
Message 3 of 9
(7,418 Views)
Accepted by topic author J.Mamakos
Tip: You can expand the property node vertically to set more than one property. The execution order will be top to bottom.
Message 4 of 9
(7,396 Views)
Thank you both. I probably should have played around with the properties a bit more but I was running out of time before having to move to something else. 🙂
Message 5 of 9
(7,384 Views)
Hi
I am not sure this where I can post a question or not, But here goes.
I am new to labview and have been tring to do something simalr,Display 4 plots fromanalog inputs on one graph.
I posted eariler, My problem is I cannot get the data to display on the graph.
I have view several different display graph and none I have tried worked.
I am using a PCI-6220 Card abd a SCB-68 connect box.
The graphs I want to bulid will have 4 to 6 channels each and display a voltage from the PCI-6220.
I have used tha DAQ Assisitant to help bulid the input but still cannot get it to run.
The last code I tried looks like this one.
Message 6 of 9
(7,227 Views)
Don't hijack TWO message threads!
Create a new message thread.
Message 7 of 9
(7,223 Views)
Where do I get to those properties?  I feel like a bonehead having to ask, but I dont see them anywhere.
Message 8 of 9
(7,014 Views)
Right-click on the graph and select Create -> Property Node -> Active Plot for one, and Create -> Property Node -> Plot -> Visible for the other. As I noted, once you create one property node you can expand it and select a different property by simply left-clicking on the property row to pop up the property menu.
Message 9 of 9
(6,989 Views)
