Enabling on-board signal conditioning with M-series USB-6289
I currently use the M-series 6289 to monitor a few analog voltages.  I noticed that it has integrated signal conditioning hardware.  How do you enable and setup this up?  Is it through S/W or through the H/W?
V/r,
Chris
(2,746 Views)
Accepted by topic author caunchman
Hi Chris,
Are you talking about the programmable 40 kHz lowpass filter? Here's how to enable it through the API: Programmable Filter on M Series Boards
Or with the DAQ Assistant:
Brad
Brad Keryan
NI R&D
(2,739 Views)
Thank you sir!
(2,722 Views)
