Enabling run time menu(run,stop,,,etc) on the VI
Hello!
How to enable run time menu like RUN, STOP on the VI(menu bar).
Kirit
(3,074 Views)
Vi Properties->Window Appearance
(3,072 Views)
Kirit,
there is no STOP button available at all. I assume that you are talking about the ABORT button. I wish that this button is removed completely in the future (what sadly will probably never happen).
Please do not use this button!
Norbert
Norbert
Expert: Geometry
(3,067 Views)
Yes ofcourse, No STOP function....
But if RUN button on VI is not enabled,,then how to use short-cuts to get RUN button enabled.
Thnx
(3,061 Views)
Eugen already gave an appropriate answer.....
Norbert
Norbert
Expert: Geometry
(3,049 Views)
