Encoder measurement with CRIO 9014 (9401 DIO module)
I'm trying to read from an incremental encoder (1000 PPR) using the setup in the title (CRIO 9014 with NI 9401 module). The problem is that when my motor reaches a speed of around 100 rad/s the pulse counting halts.
I have tried reading both in scan and FPGA mode and the same problem happens, but I think that with the 40 MHz that my CRIO is capable of providing this problem shouldn't be happening.
Am I missing some configuration in the middle of this or is that correct and my hardware just can't handle?
Thanks in advance!
P.s.: Scan interface I configured the module for quadrature encoder reading.
(2,882 Views)
What about the properties of the Timed Loop? What source/clock did you choose?
(2,846 Views)
The image I sent shows the clock as "default", so, if I'm not wrong, the timed loop is configured to work with the 40 MHz that my CRIO is capable of.
(2,830 Views)
