Encountered error -50103
Actually that is what I am trying to do it is similar to the one which I am trying to do but in that example I am trying to vary the frequency of second sub vi, can you help me with that. Is that the correct proceedure?
Message 11 of 25
(1,306 Views)
I encountered an error like this
Error -200524 occurred at 2277.vi
channels in the data does not match the number of channels in the task.
When writing, supply data for all channels in the task. Alternatively, modify the task to contain the same number of channels as the data written.
Number of Channels in Task: 2
Number of Channels in Data: 4
Task Name: _unnamedTask<33>
Message 12 of 25
(1,289 Views)
I don't think you understand what I'm trying to tell you, because you keep making the same mistake.  Did you try just running the example that you directed me to, without modifying it?  It will generate sine waves on both ao0 and ao1.
I understand that you are trying to do something different.  You are trying to run different waveforms on each channel.  You have all of the pieces of the puzzle...you're just having trouble putting them together.
If you're unable to open the code I'm posting, because you're using an older version of LabVIEW, please say so.  It's pretty clear that you're not running the code I've posted for you, and I assume that's because you're unable to do so.  It would have helped if you'd told me that.
Here is a picture which shows exactly what you need to do.  This will generate sine waves of different frequencies on each channel.
This tells you everything you need to know.  It's essentially a combination of everything I've posted for you.  Do it exactly like this.  The functions I'm using to generate your sine waves can be found here:
Message 13 of 25
(1,288 Views)
Thank you very much I am done with the code.
Message 14 of 25
(1,286 Views)
I really thank you very very much and sorry for troubling you if any.
Message 15 of 25
(1,279 Views)
You are very welcome!  We might not have understood each other the whole time, but we solved the problem and that's what matters, right?  Smiley Happy
It is working correctly for you now, I hope?  If it's not, let's keep working at it until it is.  I'm not going to abandon you.  Smiley Happy
Message 16 of 25
(1,277 Views)
Thanks for it actually it is working correctly, but the thing is can we use internal trigger such that both waves start at same point when it is triggered.
Message 17 of 25
(1,262 Views)
Hi chinna06,
You can use a start trigger so that you can control when the analog generation starts. A good example of an Analog Output Voltage Generation can be found by going to Help and selecting Find Examples in LabVIEW.
From there navigate to Hardware Input and Output » DAQmx » Analog Generation » Voltage » Cont Gen Voltage Wfm-Int Clk-Dig Start.vi
This example shows how a start trigger can be added that waits for a digital edge to start collecting data.
Milan
Message 18 of 25
(1,245 Views)
What do you mean, both waves start at the same point? You have one task, with two channels. The output of both channels will start simultaneously, by definition. Are you referring to the phase of the output signals?
Message 19 of 25
(1,241 Views)
what I am trying to say for suppose when we run the code initially there should not be any wave form output and when we give trigger then both the waves should start simultaneously and should be synchronous to each other.
Message 20 of 25
(1,235 Views)
