End User Interface--Help!
"You have a weird mix of event structures, delays, and parallel code all in one loop. it makes little sense to have an event timeout of 4 ms and and delay of 8 ms, the longer always wins."
I'm guessing that's the result of me having virtually no idea what I'm doing. (It seems that this has been noticed.) Anyway, that's why I asked for help.
"Once everything is in an event structure, the loop no longer needs to spin unless something changes."
Oh. That'll certainly clean up my projects.
"When you built an application, the users sees exactly the same front panel, but he has no access to the diagram. You can further customize the apperance (e.g. hide the menu or toolbar, the scrollbars, etc.). The appication should be set to 'run when opened.' "
That makes sense.
I appreciate all the help, thank you!
Ravens Fan: Sure, but then I wouldn't learn anything.
Amanda H: It appears that there are no programs that I can make it to soon, but I'll keep that in mind.
Message 11 of 11
(514 Views)
