End of File Encountered
Hello I am learning to write and read to and from measurement file.
I get "end of file encountered" "NI-488 Invalid argument or arguments to function call"
I am also interested if it is possible to input a signal to a simulation loop
at the "same" time that I am outputting it to the outside world.
I later on want to be able to compare a simulated result of a differential equation
with the real world response of the dynamical system that is modeled in the simulation, so that
I can easily tune the parameters of the differential equation so that I have as close resemblance as possible with the real world.
Grateful for some help
laskar01
Message 1 of 1
(2,877 Views)
