End of File error encountered
Hello! I have developed a VI with several communication links. It was 1 year of work with several Sub VIs. Suddenly the file is not opening for some reason and this error shows up. "End of File Error". Is there a solution to this problem? Kindly help. I have attached the VI with this post. Thank you.
(3,133 Views)
Hi Vinu,
easy solution: Pull an older version of this VI from your backup!
Apparently the file is damaged, LabVIEW seldomly generates VIs of just ~1kB filesize…
(3,128 Views)
