End of memory. Labview + Real time module + Compact Field Point 2120
My name is Michele Ciampichetti, I'm writing from Italy.
Frist of all, excuse for my english.
This is my first experience with Labview, and the application is not so easy. We use Labview 8.2.1
Our system is costituited by two different parts: there is a Compact Field Point 2120 as remote target whit some I/O card, and a PC used to releave data and memorize them (host).
The comunication between the two targets is performed by ethernet lan with Shared Variables not bufferized and not real-time fifo.
The problem is this: the sistem requires a big number of Vis and Variables (about 20 Vis per target and 50 variables localizated in 5 different librarys all in the remote target), and it should store data, acquisited by the FieldPoint, on a database (SQL Server 2005), one time per minute. This storage is made by Labview Database Connectivity Toolkit, and it work correctly. The problem is an excessive consumption of RAM on the PC.
The question is this: The use of many shared variables or vis, bring the memory to always grow? I try to explain myself. When we start our application, after the first minute and registration on the database, the memory grow of approximately 1,3 Megabytes. This is repeated every minute, and after approximately two ours, Labview break down and display "Not enought memory".
We look the on-line help for one solution, and we have found that the variables (local and shared), the concatenate funcion, the array and Vi indicators copy in memory their older value when updated. Is possible that this is the cause of our problem? There is a method to avoid it? How labview uses memory? It is possible set it up for not maintain older value in memory?
We need to run the application up to 4 days for complete its work, is a long test for a climatic room.
We're looking forward to hearing from you.
Best regards
Michele
Message 1 of 1
(2,735 Views)
