Engueue Message stops Runtime version
  My application works on development, but when I create a Runtime executable file of my project, my executable file can't open and the SW Version is "empty". I have to change all the "Engueue/Dequeue Message" to regular Engueue/Dequeue to get my SW Version. Can someone help me resolve this issue? Thank you in advance.
(1,964 Views)
Hi Herman,
Why do you need to hide an image inside some obscure office file format? It's so much easier to open/view images attached to your message!
And when you want to discuss code problems then it would way better to actually attach code…
  • There is no "SW version" in your image!
  • Why "can't your executable open"? Any error messages?
  • Do you check for errors somewhere in your code? If you do: do you get any errors?
(1,952 Views)
Yes, I got error as: Invoke Node System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
Inner Exception: System.IO.FileNotFoundException: C:\Desktop\ICP Express\builds\ICP Express.exe\ICP Express <append><b>System.IO.FileNotFoundException</b> in ICP Main.vi
I have two software, one did open the Executable file, the other one disappears after some microseconds (I believe it is the same error).
(1,942 Views)
Seems like you forgot to include ICP Express in your build.
(1,902 Views)
Thank you for your help. After carefully check, I found I didn't include a Queue message component VI in my source code. After added it in, the file version is displayed on front panel. Thank you all.
(1,875 Views)
