Enqueue element only if it is an updated value
How can I enqueue an element only if it is an updated value? I mean, I have a lot of data incoming and I just want to enqueue non-repeated data.
Thank you!
Message 1 of 19
(4,478 Views)
Store the previous incoming data in a shift register.  Compare the previous data to the new incoming data.  Stick your "Enqueue Element" inside the "True" case of a case structure.  Update the shift register with the most recent data.
Here's a picture (incomplete, obviously, as there's no timing in the loop, nor does it have a stop button, plus the queue has no input queue reference, but I expect you can handle those parts nicely on your own):
That's the simplest way I can think of.
Message 2 of 19
(4,462 Views)
In the example above, the enqueue have to be in the False case, to get what jmsolanof wants "I just want to enqueue non-repeated data".
Message 3 of 19
(4,452 Views)
Yes.  Good catch.  Thank you.  It was supposed to be a "not equal" function, I grabbed the wrong one from the pallette.
Message 4 of 19
(4,446 Views)
At todays copper prices, a solution with less wires is preferable. 😄
I typically use a globally initialized feedback node. Make sure to initialize it with something that normally does not occur in your data (NaN, Inf, empty string, -1, etc.)
Message 5 of 19
(4,440 Views)
Virtual wires are made of copper?!
Smiley Surprised
Message 6 of 19
(4,431 Views)
Smiley Surprised
Only the orange ones. The blue ones are Cobolt.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 19
(4,415 Views)
@Yamaeda wrote:
Smiley Surprised
/Y
I'm afraid to ask what numeric cluster wires are made of
Message 8 of 19
(4,393 Views)
All cluster wires are made of yarn and class wires are braided from any flexible material.  Variant wires are superconductors.
Lynn
Message 9 of 19
(4,382 Views)
Great- to save money on consumables I will now use as many global and local variables as I can.
Spoiler
And consume a lot more cost in debugging labor.
-AK2DM
Message 10 of 19
(4,374 Views)
