Enqueue in another VI using Application/VI Referencing?
I am exploring the possibility of being able to inject into another LabVIEW application from another to extend functionality of an application we do not want to modify. The main application is a producer/consumer state machine where the 2nd application simply needs to be able to shutdown the main application by either switching an existing boolean to true, or by adding the stop command to its message queue.
From what I've tried so far it seems you cannot change the property value of a boolean through the application/vi property nodes when the boolean is a latching mechanical button so my next idea was to try and add a stop command to the main application's queue, however, I can't seem to find much information on doing this so maybe it's not possible.
If anyone has any ideas on how to either get around changing the main application's boolean value or adding to its queue that'd be greatly appreciated.
Message 1 of 21
(2,559 Views)
Hi JCoder,
When you write "application" you are talking about two executables running in parallel?
(You don't talk about running two VIs within the very same LabVIEW environment?)
When you run two executables then they DON'T share any references (like queues).
You cannot simple enqueue data into a queue managed by a different executable.
(Any antivirus software will get nervous if that would even be possible by simple means!)
There are some ways to talk to a different (LabVIEW-made) executable, but you have to implement them first…
It seems you need to modify your "1st executable" anyway.
Message 2 of 21
(2,547 Views)
What do you mean by "application"?
If two VIs run within the same instance, i.e. inside the same compiled executable or in labview.exe (=development), then one VI can access front panel elements or queues of the other.
Upon creating a queue inside a VI, you can give it a name, and if you do the same in a second VI, that VI would acually use the queue from the first.
Front panel elements are more tricky, since you somehow need to get the reference to that boolean. If it's a latching boolean, you cannot assign it a value.
Message 3 of 21
(2,544 Views)
Yes so I mean 2 executables running in parallel.
I've attached my example of trying to trigger a boolean through referencing the Application and VI, but this obviously doesn't work due to the buttons being latching, which can't be changed.
So my question is: is there a similar method to add to an existing queue within the main executable, that way I can inject a "pause/shutdown" from the 2nd executable?
Message 4 of 21
(2,521 Views)
Hi JCoder,
Implement an additional "module"/subroutine in your 2nd executable that listens on a network port (TCP, UDP). When it receives a message that subroutine can inject the message content (your command) into the queue.
(That's how you implement remote control between executables the easy way.)
Message 5 of 21
(2,509 Views)
Thanks for the reply,
I'm not familiar with this, are there any examples or documentation you can point to for me to learn?
Message 6 of 21
(2,500 Views)
Look at the simple TCP example (HELP->FIND EXAMPLES) that ships with LabVIEW for an idea. You can add the server functionality to the existing executable and the client functionality to the new executable.
0xDEAD
Message 7 of 21
(2,488 Views)
It's actually more restricted. Most LabVIEW refnums are application context scoped. That means you can not share queues that are located in different application contexts. An application context is any target in a project but also any other explicitly opened Application refnum. For things like your host target and a realtime target this is quite obvious, they are located on different hardware and obviously can't share memory just like that. But it even applies to separate application refnum contexts inside the host target. And if it is in different projects then of course too.
Rolf Kalbermatter  My Blog
Message 8 of 21
(2,456 Views)
The easiest solution is probably a Network published variable that both can read/write.
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 21
(2,435 Views)
A couple of these solutions involve making a modification to the main application, which can't be done.
@GerdW, could you elaborate more on your solution please?
Thanks for the responses.
Message 10 of 21
(2,408 Views)
