Entering Unicode
While working on my Universal Dialog Box, I wanted an easy way to enter Unicode.
I decided to put it into a custom PopUp menu.  Seems to be working OK now.
Right-click on any object and there's a menu item: Enter Unicode into Clipboard ...
If you right-click on a text object with the text tool, you also get menu item: Insert Unicode between Text "abc" & "def" ...
where abc is the text to the left of the click point, and def is the text to the right of the click point.
Message 1 of 1
(1,195 Views)
