Entering text into string control
I want to be able to add new lines to a string control at runtime.  I have the Limit to Single Line unchecked, but when I hit the Enter key, it moves the focus to the next control.  I tried Alt/Enter, Ctrl/Enter etc, and none of those work either.  When the vi is not running, it works fine.
TIA,
Bill F
(3,372 Views)
Check your environment options (LV 8 menus)
Tools->Options->Environment
uncheck End text entry with Enter key
2006 Ultimate LabVIEW G-eek.
(3,359 Views)
The "End text entry with Enter key" is unchecked.
Bill F
(3,358 Views)
weird.
have you tried deleteing the control and re-creating it?
Is it possible to post the vi?
(3,349 Views)
I created a new vi with a string control, and it works fine.  It just doesnt work on the vi I'm working on.  I couldnt find any vi settings that would affect that behavior.  I deleted the control and recreated it - same thing
Bill F
(3,345 Views)
The only way I can recreate it is if I build 2 string controls in LV < 8 (e.g. LV 7) and assign one to have a key navigation of <Enter>.
Any chance this might have occured?  Does it always switch to a specific control?
ETA:
You can get it to happen LV 8 through the FocusKeyBind property (setting the key to <Enter>) despite this not being possible via menus (and despite what help says).
Message Edited by Jonnie 5 on 03-10-2006 11:47 AM
(3,337 Views)
AHA!  Yes it does always switch to the same control.  That button had its key navigation set to <Enter>.  I turned that off and all is well.
Bill F
(3,322 Views)
