Enum, Ring, Kombinationsfeld
Hallo,
Ich möchte ein Feld benutzen das programmatisch änderbar ist.
Das Feld hat 3 Strings. Wärend des Programmablaufs soll sich der String ändern. Das ist mit dem Eigenschaftsknoten möglich.
Aber es soll sich auch die Anzahl ändern.
Aber es steht immer auf "3 Felder" fest.
Wie kann ich diesen Wert ändern wärend des Programmablaufs, z.b. Boolisch
Worin besteht der genaue Unterschied zwischen Ring, Kombinationsfeld und Enum?
Message 1 of 16
(4,055 Views)
Hi Simon,
enum: you define this at programming, cannot be changed on runtime, elements are counted up automatically, starting at 0
ring: you can define this at programming AND change while runtime, elements can have arbitrary numbers
What's an 'Kombinationsfeld'? Can you attach a picture?
Message 2 of 16
(4,040 Views)
I'm guessing that's a combobox.
Jarrod S.
Message 3 of 16
(4,026 Views)
well, I never used comboboxes before...
So I can only guess: comboboxes seems to behave like rings, they just give you the string instead of the number as their data type.
Message 4 of 16
(4,021 Views)
k, thx for the elucidation.
My real problem is a other one. I may explain it with a picture.
You can see here 2 Arrays with rings in a cluster.
I want the following:
If you for example enter in the first array "Netzteil 6033A", that the chooseoptions in the next ring in the Art array should be a other one ase for example the chooseoptions from "Ausgabetext" in array 1.
The problem is not to change the strings in the rings of the 2 array as a function of the first array.
I also want to change the number of strings in they special datatype in the array. How could i do that?
Message 5 of 16
(4,005 Views)
Hi Simon,
in an array all elements have to have the same properties! So you cannot have in element #2 other strings than in element #1!
Message 6 of 16
(3,998 Views)
k,
now i have a nother question:
Can i change the view of a datatype in a cluster program dependent?
I have a Cluster with 5 Ring datatypes in it. I want to choose the view of those rings with for example a boolish element from somewhere else.
Is that posible?
Message 7 of 16
(3,979 Views)
In a cluster you are free. You can have a lot of controls of the same type with different properties.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 8 of 16
(3,977 Views)
Yes, hmmm  how should i explain that at the best way.
I have a Cluster in a Cluster. In that Cluster, witch is in the Cluster, are 5 Rings. And i wnat to make them visible or not visible.
So i need settings, where i can choose settings of elements in the elements. I cant found them...
What is to do?
Message 9 of 16
(3,974 Views)
You can access the element of a cluster using the controls property. This gives you an array of control references.
Have a look at the attached picture.
Using LV8.0
Message 10 of 16
(3,973 Views)
