Enum constant
Im trying to pass the value from an enumerated constant to an Addition Function, however it seems to pass the numeric value instead of the string label. When I wire in an indicator, LabVIEW does display the string label instead of the numeric value, so why doesn’t it pass the string label to the Add function??
Example attached.
Many thanks
(2,608 Views)
its ok, im being silly.. solved
(2,597 Views)
