Enum control not editable in specify module
I created an enum control in LV8.0 and am trying to use the VI in TS3.5 as an action.  When I specify module, the drop-down control for the enum is missing and the value is can not be editted.  I've tried changing names of enum choices to as simple as ""one", "two"", but still can not edit it in TS.
(2,452 Views)
Hey Josephio,
Have you wired the enum up to the connector pane in LabVIEW as an input?  TestStand will not recognize the enum control from your VI (or any other controls or indicators, for that matter) until you wire them to the LabVIEW connector pane.
Are you seeing the enum at all in TestStand's specify module window?  Is it showing up as an input, however the dropdown window doesn't appear?  Please post a screenshot if the above advice doesn't help you and I'd be happy to assist you further from here.
Derrick S.
Product Manager
NI DIAdem
(2,421 Views)
