Enumerated Type control
Is there a way to retrieve the string from a wire coming from an
Enumerated Type control? Case statements do this, but how do I pull out
the string?
I'd like to avoid using the control's Strings [] attribute node with an
Index Array to get the string. Any way to do this?
Chris
(3,629 Views)
> the string?
There are three ways to get the strings. The first way is to use
the attribute node like you mention. A second way is to use the
Format into String node with the %s specifier. This will do one
value of the enum at a time. The third way is to flatten the
enum into a string and parse the type information that comes out
of that node. I'd definitely recommend the first or second methods.
Greg McKaskle
(3,629 Views)
