Environment Mode
Is there a way to determine if my application is run from the IDE or a stand-alone .EXE?
JY
(3,448 Views)
Accepted by topic author jeffyy
(3,436 Views)
Yes, have a look at this knowledge base article and look at the property node that has been used.
http://digital.ni.com/public.nsf/allkb/FD7DE8BC8FFC256C862565F4006BE363
More specifically:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvprop/app_appkind/
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,427 Views)
There surely is.  There is a nice property node that will do exactly that (picture attached).
Application Control...grab a property node and place it on your block diagram...right-click on the property...select "Properties"...select "Application"...select "Kind".
The property node will return the environment.
Hope this is what you're looking for...
d
(3,424 Views)
