Equipment apa dan darimana mencarinya
Izin bertanya masters, untuk equiment ini ambilnya darimana ya? dan kegunaannya apa?
terimakasih banyak, saya baru menggunakan labview, mohon bimbingannya
saya menggunakan labview 2012
(2,211 Views)
Accepted by topic author brighti
Hi dinsul,
@brighti wrote:
Permission to ask masters, where did you get this equipment from? and what use?
thank you very much, i'm new to using labview, please guide
i use labview 2012
It's a string-to-number conversion function! Look for it in the string->"Number/string conversion" function palette and read the context help for that function…
(2,190 Views)
I'm new into Labview and I can't find this equipment, can someone tell me where I can get this please?
I'm using labview 2012
(2,175 Views)
Dear masters, please help me how to connect the equal comparison to subtract. I'm trying to do like the first pict but always error like the second pict
thankyou
(2,169 Views)
Thank you so much, it's really help me. But can you please tell me where can I get this equiment?
(2,164 Views)
Hi dinsul,
You really should take the Training resources as offered at the top of the LabVIEW board. Really!
This is a boolean (see that "TF"!?) indicator (see that triangle at the left side!?) terminal (set to icon view, which I don't like)!
EDIT:
I merged your threads as you basically ask on guidance to actually learn LabVIEW! See my comment above on Training resources…
You cannot subtract a float from a boolean value as you can read in the context help when hovering the mouse over the broken wire. (Again: do the Training courses!) In your blurry image at the left border there probably is a multiply instead of an equal function…
(2,156 Views)
