Equivalent Command for CL HIL Write in Roboclaw controller
Hi
I'm using a Roboclaw 2X7A controller to control the DC motor for my inverted pendulum project.
I'm using VISA commands in LABVIEW to communicate to the motor controller via an USB cable.
I'm taking reference from Quanser's Inverted Pendulum project.In that they use a command called CL HIL Write to write an analog voltage for the control input.Can anyone please help me by explaining what that command exactly does and if possible guide me on what command I should be using for performing  the same function in Roboclaw using VISA commands?
I'm attaching the simple VI which is used to model the motor, from which I took the reference.
P.S Ideally I wanted to achieve an acceleration  that is proportional to the voltage that I'm sending in.
Thanks in Advance
Regards
Denesh
Message 1 of 1
(2,519 Views)
