Equivalent function for Write to SGL file.vi
Hi all,
Is there any function equivalent to Write to SGL file & Read from SGL file vis (available in LV7.1)available in LV2009?
In LV7.1 I can make use of this function to write mainly the application password (after converting to byte array ) into a file using this Write to SGL file.vi . This when try to open it using notepad or something like that it is not in user readable format. I could not find the same kind of functionality in LV2009. Am I missing out searching function palette or it is loaded in someother form which I could not decipher?
Any help is appreciated.
Kousy
(3,700 Views)
Hi!
The write to binary VI:
in the File-I/O tab...
Greets CR
(3,693 Views)
Just to point out: that's not a very secure way to save a password. It's fairly trivial to find out what it is. If this is intended to be distributed you should consider a more secure way to store a password.
(3,681 Views)
