Erreor compilation LabView FPGA ERROR:MapLib:979 & 978
We have a labViwe FPGA application. When we compile the FPGA VI, we have the following errors  :
'ERROR:MapLib:979' and ERROR:MapLib:978'
If we compile several time the same projet without modifying the code ou the option, we obtains errors or a good compilation.
See the report 'rep.txt'.
Benoit.
Message 1 of 11
(4,478 Views)
I don't see the report, and can you send me your VI, in order to look at it.
Nacer M. | Certified LabVIEW Architecte
Message 2 of 11
(4,448 Views)
If i select a file to join to the message, the click to the 'send' button always fail.
Can i send you the file to your email directly ?
Regards.
Benoit.
Message 3 of 11
(4,437 Views)
If you want you can create a zip, and put him in our ftp site : ftp.ni.com/incoming, then you can give me the name of the file in order to find it.
Message 4 of 11
(4,420 Views)
I put hte file 'rep.zip' in ftp://ftp.ni.com/incoming.
Regards.
Benoit
Message 5 of 11
(4,407 Views)
Concerning the error there is two possibility, the first is maybe the path of your directorie and the name of your VI are too long, can you try to put your project in a folder of the C: ? and put a shorter name.
If this doesn't solve the problem, you will have to unistall LV FPGA, and reinstall it.
Can you check that?
Message 6 of 11
(4,387 Views)
Please read the following page au the Xilinx web site :
http://www.xilinx.com/support/answers/33744.htm
The error '979' is documented
Regards.
Benoit.
Message 7 of 11
(4,357 Views)
Were you able to change any of the threee compilation options mentioned in http://www.xilinx.com/support/answers/33744.htm and then compiled again? If so, did it compile without errrors?
Message 8 of 11
(4,280 Views)
Message 9 of 11
(4,260 Views)
Message 10 of 11
(4,260 Views)
