Erroe with SCXI configuration
I have a SCXI 1000 block chassis connected to 2 1300 series terminal blocks. I recently installed NI LABVIEW software. When I try to auto-detect the chassis this is what I get: "SCXI-1129 IN SLOT 1 does not have an accessory configured". So it does not detect any terminal block. Even if I have a working VI I am not able to get any data.(possible because of this error). I also tried manually selecting 1336 as terminal block but it didn't seem to work(no data).
Could anyone please tell me what I should do about this?
(2,574 Views)
The SCXI-1129 is a switch used for routing signals and does no data acquisition.  What are you trying to switch?  What is performing the acquisition?
h_baker
(2,555 Views)
