Error 0xc0000005
Ref: Labview 2024 32 bit
Ref: Windows 11
I have some code that reads and writes a text file to the local drive. This simple task works well within the Labview environment. However when it is compiled to an exe, I am able to read the file but the program crashes when trying to write to the file, giving the error shown below. I assume it is a write access error, however I am in admin mode and have also launched the executable by selecting admin mode. The problem wont go away.
Is this a compatibility issue with Windows 11 / Labview 32 bit, or is there a setting in the app builder that needs to be set, or something else?
(1,896 Views)
That's a memory access violation.  The app tried to use memory that it does not own.
Bill
CLD
(Mid-Level minion.)
(1,861 Views)
That error number is common enough to recognize on sight.  It's an "access violation" error, but it doesn't mean you lack admin access to something.  It means something in LabVIEW is trying to access a location in RAM that it's not allowed to access.  Sometimes this is a null pointer, other times it's a reference that points to memory that was allocated but later freed and is now outside of the application's memory space.
For the most part LabVIEW's core code, such as file writing, has been tested and debugged extensively so it is very rare for LabVIEW all on its own to generate this error, which is why if you look at other posts with the same error code they often direct you to look at 3rd party code using DLLs or ActiveX as the most likely cause.
Since you're convinced that writing to the file causes it, here's a few important checks to do that could help with troubleshooting:
First, in your current code, have you checked to see which exact subVI or node causes the crash? You could do this in many ways, but since you seem pretty sure writing files is causing the problem I'd suggest adding delays and some code to put status updates on a visible front panel somewhere so that it slows down the operation and really lets you be sure of the exact node that crashes everything.
Second, can you create a very small EXE that runs by itself that replicates the problem but doesn't do anything else?  Meaning something that just runs the file saving routine with a set of dummy data, or an even smaller example.  If you can do that and post the VIs that make up that EXE here, other people can attempt to build it and see if it works for them or not.
Third, have you tried this on any other PC or OS?  If you could see if another W11 PC, or a W10 PC, could run it with no crash, that could help check to see if it's a problem specific to your W11 PC or to W11 in general.
(1,860 Views)
Thanks for your advice;
On further investigation, the Labview application works fine in its own environment. When built into an exe I am able to read the file but the application crashes (0xc0000005) when writing to the file.
I tried building the exe on another Windows 11 pc and it worked fine, no problem, so my thought is that there must be something wrong with the Windows 11 pc software.
Maybe there is a setting in Windows 11 that I am not aware of. Or maybe there is a method of checking/resetting Windows 11 in particular for file access?
(1,815 Views)
Hello @stevesteve. How did you resolve the error?
We face the same error in Windows 11 PC. We run the same exe simultaneously in two Windows 11 PCs & suddenly it crashed in one of the PC & in another PC, it was running without any error. Your troubleshooting will help us resolve the error quickly. Thanking you in advance.
(850 Views)
it was a strange one. it was actually caused by a variable that was assigned a value at the beginning of the Labview program. Labview coped with it as expected and so did Windows 10 when compiled. Windows 11 had random crashes with that error code. So worth having a look at any assigned variables in Labview.
(793 Views)
Crashing with this exception basically tells you nothing about what LabVIEW code might be causing the crash. I would start with just trying to create the simplest reproducing case you can from your application or look at what changed from your code running well to crashing.
(719 Views)
