Error 1 occurred at Close
In "Write into file.vi"
the file is opened and is writen normally by choseing ile options.Opened file refnume is cycled by shift registr.
But when file option is "close" error is coming.
I cant understand why???
I even reinstal my labview
(4,074 Views)
Just by looking at your code: the first time you call Write into file.vi with Close option, it works ok. But then while loop cycles and the second time you pass null reference into Close file - which produces error.
(4,063 Views)
I use this vi as subvi, at first time I call it with "open" option, then many times with "write" option, and no error, but the when i coll it with "close" option the error is coming.
(4,057 Views)
Your example program isn't really good.  You can be constantly opening the file without closing it.  Use an event structure and add a button to execute the chosen action.
Using highlight execution, it is obvious that the close case is actually being called multiple times due to the polling architecture you have.  The second time the close case is called is when you get the error.
(4,055 Views)
