Error 1 occurred at EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Invoke.vi.ProxyCaller
I started with the LabVIEW version of the TestStand operator interface and I replaced the testexec.llb with all its respective VIs.  I then saw this error.  Any suggestions?
Possible reason(s):
LabVIEW:  An input parameter is invalid.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
(2,658 Views)
Hey mrbean!
To get started helping you with your issue, I just wanted to ask a few quick questions.  Which versions of LabVIEW and TestStand are you using?  Are you using the LabVIEW project file or just the LLB by itself?  Also which version of the OI are you replacing?
Thanks!
Andy F.
Message Edited by Andy F. on 03-27-2006 05:51 PM
(2,651 Views)
