Error 1 occurred at Invoke Node in openvi.vi
Hello,  in openvi.vi, I use Invoke Node to run showchannel2.vi,  I met problem about error 1. please see attachment file.
This problem have been described below absolutely.
Possible reason(s):
LabVIEW:  An input parameter is invalid.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
I don't know why? How can I overcome this question?
Thank you very much
(3,804 Views)
Accepted by topic author presun
The datatypes of your controls don't match. In the subVI you have a U8. In the parent VI the slider is a DBL. Change the slider's datatype to a U8. You should also make sure you have a valid range on your slider. In the subVI you're subtracting 8 from the input value, so it seems you're wanting a control with a minimum value of 8.
(3,797 Views)
