Error 1003 occurred at Invoke Node
While making Exe , when i click on source files option to fill required details, it gives below error:(See below attached Snap shot)
Error 1003 occurred at Invoke Node in AB_UI_Load_Page.vi->AB_UI_FRAMEWORK.vi->AB_CreateNewWizard_Invoke_CORE.vi->EBUIP_CreateNewWizard_Invoke.vi->EBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Select File>>Open to open the VI and then verify that you are able to run it.
Method Name: Run VI
VI Path: C:\Program Files\National Instruments\LabVIEW 2012\resource\Framework\Providers\Builds\AppBuilder\AB_UI_Page_Source_Files.vi
(3,090 Views)
I can't open .docx files.
Are any of the VIs in your project broken?
(3,063 Views)
Please check all your VIs. Some member VIs still cant be compiled.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,052 Views)
