Error 1026 How To Build the G Web Server Using CGI Into an Executable
I have tried both building my own CGI application using the Application Builder and building the listdir application, by following the instructions given in the document "How To Build the G Web Server Using CGI Into an Executable
" (from: http://digital.ni.com/public.nsf/websearch/17427B623FE6083F86256D1300705CFE?opendocument&Submitted&&node=133020_US), but in both cases, when I launch the built application, I get an error 1026 in HTTP Server Control.vi, with the source "??? in HTTP Server Control.vi" I've attached a copy of my build script.
(4,122 Views)
Do you receive that error message when you launch the executable or when you try to "start" the web server? Also, have you mass compiled the dynamic VI included in the instructions?
(4,122 Views)
I have mass compiled the dynamic VI included in the instructions.
The error message occurs when I launch the executable.
(4,122 Views)
This is rather curious. Would you mind posting the executable you built out of listdir.vi?
(4,122 Views)
Built listdir application, as requested. Sorry it took so long, had problems uploading.
(4,122 Views)
