Error 1031 from Open VI Reference when run in executable
I am trying to design a plugin system into my executable, so that it can call and run vis from a particular folder at runtime. The vis in this folder will change, but they all follow the same template for the connector pane. This is the vi I use to call the plugin vis. It all runs perfectly when I run it in development. But when I try to use the built executable, I get "Error 1031: LabVIEW: VI Reference type does not match VI connector pane".
Does anybody know why this doesn't work in my executable?
I'm using LV 2014.
(3,405 Views)
Thank you for attaching your code so we could add debugging tools and see what is really going on ... oops, you didn't attach your code!  Well, I don't feel like guessing, I'd rather test ...
Bob Schor
(3,378 Views)
Bob Schor
Haha, I happily would if I could. I figured out that it’s an issue with conflicts. My plug in has the “same” typedefs on its pane as my executable, but’s its own conflicting references. So now I need to work on untangling the dependency mess I’ve made.
(3,374 Views)
