Error 1031 in built application
I did a right-click on one of my VIs and did a Call Setup to make it a dynamic VI.  It works fine when I run the program in LabVIEW, but when I run the built application, I get error 1031, "VI Reference type does not match VI connector pane.".  I am passing the VI an Error In cluster, a Queue, and a Structure Control Refnum.  The other Dynamic VIs that don't have input parameters work fine.  Any idea why there's a problem (and how to fix it)?
(4,299 Views)
Can you post your caller VI code (and subVIs) that contains the subVI on which you did the "Call Setup"?
What version of LabVIEW are you using?
Message Edited by Bill@NGC on 09-14-2007 10:50 PM
(4,293 Views)
I've a problem same like this.
Any update on this problem and How to fix it?
(4,090 Views)
Hai,
Search the forum with the keyword - error 1031. You will get some 22 messages. Try to go through all and see whether that solves your problem.
Mathan
(4,077 Views)
Possibly this one?
Be sure to let us know if you don't find (or do find) a solution and what it was.
David_B
(4,057 Views)
Hello, I have the same problem using LV2013. What is the solution?
Cristian
(3,629 Views)
