Error 10401 - PCI 6023E
Hello everyone,
I have a LabView code running on LabView 6.1 (on Windows 2000).  It has a PCI 6023E DAQ card.
Everything was working fine for many days, until suddenly today I got the Error 10401 - occured at AO Single update.
if I click OK, the code tries to run then displays the same error again and again.   I have attached the LabView code.
I checked in NI-MAX, and the device is located there as (Dev1), and seems to be fine.  I also tried restarting the computer but still get the same error.
What might be the problem?  Any help is appreciated.  Thanks.
(2,326 Views)
Hi nithyan2,
I believe that you are using Traditional DAQ drivers, please take a look to this article.
Best,
Carmen C.
(2,310 Views)
