Error 10401
I have reinstalled windows and tried to reinstall labview and NI DAQ drivers and I found error 10401 (source: AO Single Update) when I tired to start the vi program on output board (PCI 6073). There was no error on input board (PCI 6034E). I can see both two devices on MAX and the device number is correct. I have tried to reinstall the drivers for several times. Still could not solve the problem.
My labview version is 6.0
MAX 3.0.2
NI-DAQ: Tried both 6.9.3f3 and 7.1.
I have looked up the compatibility and found they were compatible. I also found some similar discussion here but still could not figure it out. Anyone met this problem before and could help me out? Appreciate it!
Thanks!
Will
(3,346 Views)
Have you tried this? http://digital.ni.com/public.nsf/allkb/46F78EDD19BA0CC386256CEE007201FC
(3,319 Views)
Yes, I tried all three possible solutions there but it didn't work.
(3,296 Views)
