Error-10403 occurred at DIO Port Config
Hi:
I´m trying to work a Pci-6013 board in a suttle Sk-41G, using NI-DAQ 6.9.3 and Lab-VIEW 6.i evaluation copy. The analog channels work fine, but the digital ones do not. Using the Write to digital line.vi from the digital I/O palette in the Data Acquisition palette in the functions palette I get the 10403 error when i try to act on a virtual channel defined in the max explorer. The device and the line and port width are correctly introduced, but in the digital channel control from the vi only displays "Write Relays", and none of the digital virtual channels defined in the max explorer, so i usually introduce the name of the digital channel by keyboard, not knowing wether the digital channels defined in the max should be display
ed in this control directly.
Any hinch on this isue would be very much apreciated.
(2,890 Views)
In order to see your digital channel names, have you tried right-clicking on the the DAQ Channel Name control and navigating to Select DAQ Class>>Digital Output?
Best Regards,
Doug Norman
(2,890 Views)
Hi Doug:
Yes, i tried to visualized the virtual channels defined in the Max through the Daq channel name control but i couldn´t see them. When i change the mode from analog input to dio it doesn´t change anything. The wierd thing is that even not being able to see the analog channel defined in the max, it works. The ones who do not are the digital ones.
Thanks for the hinch Doug; i gess i´ll try to reinstall everithing, including windows, lets hope that know it´ll work.
(2,890 Views)
