Error 1048: Matlab script node: passing 2D Array from Matlab to LabVIEW
Hi 🙂
I ran into 1048 error when using mathscript node in LabVIEW. The next image shows the code that produces the error. I get a similar error on LabVIEW 8.2 on an windows XP machine.
The following examples use similar code but don't pass on 2D arrays from the MatLab code to LabView. None of those run into 1048.
I need to use the videoinput function in MatLAB because updating and installing new tools or modules is not a valid option on the windows XP computer which is connected to the camera of interest.
Fluo
Message 1 of 1
(1,628 Views)
