Error 1048 occurred at LabVIEW: LabVIEW failed to get variable from the script server. Server:"??? Undefined function or variable 'volt_out'.
Hi everyone.  I am running a MatLab (2007) script node in my VI (LabVIEW 8.2) and I am getting an error whenever I run the VI.  The error is:
volt_out is defined in my code so I don't understand why I keep getting the error.  I attached my MatLab script.  Any thoughts on this would be appreciated.  Thanks for the help.Script.JPG
Message 1 of 10
(12,385 Views)
Thank you for your response.  I actually already looked at the link you sent me and their explanation of the cause of the error is not my problem.
1.  The variable name volt_out is not the same as a function name in MatLab
2.  I am not using the clear all function in my script.
3.  I am not utilizing a function such as "input"  that requires interaction with the command window.
Any thoughts as to what is going on?
Thank you for the help.
Message 3 of 10
(12,351 Views)
Hi baseball07,
Are you able to run the script directly in MATLAB?
Message 4 of 10
(12,335 Views)
The MatLab code seems to be ok.  I think it is a problem with interfacing with LabVIEW.  I still cannot figure out what it could be.  Are there any more suggestions?  Thank you.
Message 5 of 10
(12,140 Views)
Hi baseball07,
To go back to Kyle's question, are you able to run this same script in MATLAB? Have you tried dropping down a new MATLAB Script Node and copy/pasting your script into that one? Have you tried starting from a blank script and incrementally building and testing your script?
Aaron P
http://www.ni.com/support
Message 6 of 10
(12,075 Views)
I have the exact same problem. The script is working in Matlab. Any thoughts?
Message 7 of 10
(11,832 Views)
To go back to what Aaron was saying, did you import or copy/paste the script into the node? How about taking portions of the code and slowly building your script in the MathScript node.
Stephanie A.
Americas Marketing Manager
Message 8 of 10
(11,802 Views)
Hi Stephanie,
Thanks for the reply. It works now. At the beginning of my function i used a relative path and the current directory was not set properly. The reason that i got confused was that I got an error message saying "Undefined function or variable". The reason for this was that I had an "return" statement inside an if such that the function was quited before my variable was set. It is always more than one error 🙂
Another thing that confused me was that you have to re-open the vi after you make changes in the Matlab script. I guess Labview make a copy of the m-file when opening ?
Best regards
Marius
Message 9 of 10
(11,791 Views)
Hi. I got the same problem. what does it mean, you said “The reason for this was that I had an "return" statement inside an if such that the function was quited before my variable was set”?
Message 10 of 10
(10,759 Views)
