Error 1055 occurred at Property Node
I am very new to LabView and cannot understand why this error message continues to display each time I run the program.
Attached is my program with the error originating from the attempt at displaying the 3 different cursors
(5,391 Views)
1055 means "Object reference is invalid".
The problem that you haven't cursors. Just create three cursors, then error 1055 goes away.
Andrey.
(5,372 Views)
Hello, RocKyle!
Andrey is right on the money - were you able to try this yourself?
Will Hilzinger | Switch Product Support Engineer | National Instruments
(5,358 Views)
Yes! And thank you. I thought that creating active cursor through the property node automatically created the cursors, but now my confusion has cleared up.
Thanks again!
(5,356 Views)
You can create cursors programmatically if you need to, by modifying the Cursor List property. This is a 1D array of cursors. There's an example that ships with LabVIEW that shows you how to programmatically control cursors. Open the Example Finder and search for "cursors".
(5,345 Views)
