Error 1055 occurred at Property node...
hi everyone
I'm trying to plot a graph of voltage
Why this error?
Thank you very much
(4,411 Views)
I guess you are simply using the reference control for waveform chart instead of creating waveform chart reference. Did you take this code through a snippet? Ok, right click the waveform chart Create>Reference then wire this reference to the property nodes.
(4,401 Views)
I'm not going to go into why you get an error.
I am going to ask you what you were thinking!  What were you thinking?
You wired a value to the terminal then created a write value property node to the same terminal......... Don't do that its a waste of BD space!  really the terminal will write the value just fine.
(4,384 Views)
Where are you getting the waveform reference? This appears to be a subVI.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,379 Views)
Hi everyone, sorry my english..
http://forums.ni.com/t5/LabVIEW/stream-data-from-a-subvi-to-the-main-vi/m-p/2205150/highlight/true#M...  >>  Anexo >> vi references.zip >> 3 (SUBVI)
I created a sub vi ... I want to show the graphs on main VI and I'm using Control refnum.
(4,355 Views)
