Error 1055 occurred at property node
I am trying to use a cursor in my graph as a limit line.  After trying both methods in creating a property node, right click etc and via pallete, i still get this error?  I have attached block diagram jpg.  Thanks
(3,733 Views)
The default active cursor is 0, so this probably means you didn't create any cursors.
You can create a cursor by displaying the cursor legend and adding one or by using the Cursor List property.
___________________
Try to take over the world!
(3,725 Views)
