05-28-2008 01:04 PM
05-29-2008 11:47 AM
Hi Nathan,
Refer to this post for specific instructions on replacing the EIO_SpecifyEIONode.vi and make sure you replace the IO node on the block diagram afterwards. Thanks and have a great day!
06-10-2008 10:52 AM
06-11-2008 07:34 PM
Hi Nathan,
Sorry for the confusion. The block diagram is where the LabVIEW code for your FPGA is. If you expand your FPGA in your FPGA project you should have a VI. You can open that VI and there will be two windows, a front panel and a block diagram. The block diagram is white and if it doesn't show up automatically you can go to Window»Show Block Diagram and it will show up. You will see the old I/O node, delete it and then right click on the block diagram to bring up the functions pallet. Go to FPGA I/O and then I/O node. Click on the I/O node and drag it onto your block diagram. You will need to wire it up the same way the old one is wired. I have included a screen shot of the block diagram, functions pallet and the I/O node.
