Error 1073 when building LabVIEW app which calls LabVIEW dll
I am trying to use application builder to build an application that calls a dll created in LabVIEW. I get an error referencing a vi within the dll (Parse Stored String(multibyte).vi) saying that "This property is writable or this method is available only when the VI is in edit mode." The only option is to Continue which cancels the build. I had sucessfully built this application prior to including vis that call the dll and the program runs fine in the development environment.
Do you have any idea what is causing this and what I cam do about it?
(2,579 Views)
I have found a temporary workaround in which I created a dummy dll that removed all functionality from exported vis but had the same name and function signatures. I then built the application using this dummy dll. Once complete, I replaced the dummy dll with the real dll.
This is not a satisfactory work around because we have to build and maintain two dlls. Also, I'm not sure we can do the same trick when creating the installer with application builder. So, I'd still appreciate any help you can give.
(2,579 Views)
