Error 1073676294
The following codes i posted below is not written by me.
Now i got a problem with the setting.
Basically, i have a NI camera with Gige and Rs232 connection to the computer.
I can snap picture using MAX or VBAI.
but i cant get my picture in the LABview executable program.
It shows 1073676294 error message.
i know its just a warning message, but seems like my camera doesn't work well with my program.
I suspect is connection/setting problem.
Can anyone help me with the setting problem, if possible, no source code change attempts.
(As this program is proved to be working fine for 1 year already)
here are the codes.
(4,289 Views)
more attachments.
(4,284 Views)
i got the "image capturing failed" message
(4,270 Views)
help
(4,235 Views)
help pls..
i got a 10s delay for RS232 connection
I have an issue regarding NI1722 smart camera.
I've setup the camera using MAX and able to grab picture in MAX.
Now i connect via RS232 using hyper terminal(COM1), when i type "lo", i will receive "okok" but with 10 seconds delay.
If i type in any other than "lo", i will get instant reply of "NAN NAN".
I suppose to receive an instant reply message "okok" when i type in "lo" , am i right?
The setting for hyper terminal is by default.
(4,224 Views)
