Error - 1073807171 Cannot retrieve Configuartion descriptor
Hi
I am trying to make a Driver for one Proteus USB Sample using NI-VISA Driver Wizard, But I am recieveing a Error - 1073807171: Cannot retrieve Configuration descriptor. Try Disconnecting and reconnectiong your USB device from the system and refreshing the device list.
Can you please guide me what may be the problem..??
(3,480 Views)
I have the same problem, and I created physical device does not work, Windows sends me the message USB: error 43
(3,149 Views)
Please be specific as to the actual physical device. Using the VISA Wizard is almost always a mistake. You delete the vendor provided driver when you do this. Always a good idea to use the provided driver.
(3,137 Views)
